ممنون از پاسختون. متاسفانه آپلود نشد و خطای couldn't upload داد( کلا این مشکلو من با سیستم جدیدتون دارم). بخش آخر رو کپی میکنم. باز لینک آپلود فایل نوت ارور قرار میدم.
Final Error Summary =====
The following error categories occurred. Consider correcting or noting Nominally Unused Constructions
..The nominally unused constructions warning is provided to alert you to potential conditions that can cause
..extra time during simulation. Each construction is calculated by the algorithm indicated in the HeatBalanceAlgorithm
..object. You may remove the constructions indicated (when you use the DisplayExtraWarnings option).
** EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors.
************* EnergyPlus Sizing Error Summary. During Sizing: 58 Warning; 0 Severe Errors.
************* EnergyPlus Terminated--Fatal Error Detected. 171 Warning; 1 Severe Errors; Elapsed Time=00hr 11min 54.44sec
