non-convex severe error
سارا عبادی سارا عبادی
624 بازدید 4 پاسخ
با سلام خروجی انرژی پلاسم همچنان non convex  ارور میده.  solar distribution رو هم کم کردم حتی گذاشتم دو ولی باز هم ارور میده نمیخام حجمم رو دست بزنم. چیکار باید کنم؟ واینکه خروجی میتونم بگیرم و نمودار میده بهم ولی میخام ببینم میشه به داده ها مطمعن بود؟
            {0;0;0}
0. Current document units is in Meters
1. Conversion to Meters will be applied = 1.000
2. Current document units is in Meters
3. Conversion to Meters will be applied = 1.000
4. [1 of 8] Writing simulation parameters...
5. [2 of 8] No context surfaces...
6. [3 of 8] Writing geometry...
7. [4 of 8] Writing Electric Load Center - Generator specifications ...
8. [5 of 8] Writing materials and constructions...
9. [6 of 8] Writing schedules...
10. [7 of 8] Writing loads and ideal air system...
11. [8 of 8] Writing outputs...
12. ...
... idf file is successfully written to : c:ladybugunnamedEnergyPlusunnamed.idf
13.
14. Analysis is running!...
15. ...
Done! Read below for errors and warnings:
16.
17. Program Version,EnergyPlus, Version 8.5.0-c87e61b44b, YMD=2020.07.03 00:46,IDD_Version 8.5.0
18.
19.    ** Warning ** IP: Note -- Some missing fields have been filled with defaults. See the audit output file for details.
20.
21.    ************* Beginning Zone Sizing Calculations
22.
23.    ** Severe  ** DetermineShadowingCombinations: There are 1 surfaces which are casting surfaces and are non-convex.
24.
25.    **   ~~~   ** ...Shadowing values may be inaccurate. Check .shd report file for more surface shading details
26.
27.    **   ~~~   ** ...Add Output:Diagnostics,DisplayExtraWarnings; to see individual severes for each surface.
28.
29.    ** Warning ** ManageSizing: For a plant sizing run, there must be at least 1 Sizing:Plant object input. SimulationControl Plant Sizing option ignored.
30.
31.    ************* Testing Individual Branch Integrity
32.
33.    ************* All Branches passed integrity testing
34.
35.    ************* Testing Individual Supply Air Path Integrity
36.
37.    ************* All Supply Air Paths passed integrity testing
38.
39.    ************* Testing Individual Return Air Path Integrity
40.
41.    ************* All Return Air Paths passed integrity testing
42.
43.    ************* No node connection errors were found.
44.
45.    ************* Beginning Simulation
46.
47.    ************* Simulation Error Summary *************
48.
49.    ** Warning ** The following Report Variables were requested but not generated
50.
51.    **   ~~~   ** because IDF did not contain these elements or misspelled variable name -- check .rdd file
52.
53.    ************* Key=*, VarName=COOLING COIL ELECTRIC ENERGY, Frequency=Hourly
54.
55.    ************* Key=*, VarName=CHILLER ELECTRIC ENERGY, Frequency=Hourly
56.
57.    ************* Key=*, VarName=BOILER HEATING ENERGY, Frequency=Hourly
58.
59.    ************* Key=*, VarName=HEATING COIL TOTAL HEATING ENERGY, Frequency=Hourly
60.
61.    ************* Key=*, VarName=HEATING COIL GAS ENERGY, Frequency=Hourly
62.
63.    ************* Key=*, VarName=HEATING COIL ELECTRIC ENERGY, Frequency=Hourly
64.
65.    ************* Key=*, VarName=HUMIDIFIER ELECTRIC ENERGY, Frequency=Hourly
66.
67.    ************* Key=*, VarName=FAN ELECTRIC ENERGY, Frequency=Hourly
68.
69.    ************* Key=*, VarName=EARTH TUBE FAN ELECTRIC ENERGY, Frequency=Hourly
70.
71.    ************* Key=*, VarName=PUMP ELECTRIC ENERGY, Frequency=Hourly
72.
73.    ************* Key=*, VarName=ZONE VRF AIR TERMINAL COOLING ELECTRIC ENERGY, Frequency=Hourly
74.
75.    ************* Key=*, VarName=ZONE VRF AIR TERMINAL HEATING ELECTRIC ENERGY, Frequency=Hourly
76.
77.    ************* Key=*, VarName=VRF HEAT PUMP COOLING ELECTRIC ENERGY, Frequency=Hourly
78.
79.    ************* Key=*, VarName=VRF HEAT PUMP HEATING ELECTRIC ENERGY, Frequency=Hourly
80.
81.    ************* There are 2 unused schedules in input.
82.
83.    ************* There are 2 unused week schedules in input.
84.
85.    ************* There are 6 unused day schedules in input.
86.
87.    ************* Use Output:Diagnostics,DisplayUnusedSchedules; to see them.
88.
89.    ************* EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors.
90.
91.    ************* EnergyPlus Sizing Error Summary. During Sizing: 1 Warning; 0 Severe Errors.
92.
93.    ************* EnergyPlus Completed Successfully-- 3 Warning; 1 Severe Errors; Elapsed Time=00hr 00min 46.31sec
94.
اگر هدف شبیه سازی انرژی هست بله ولی اگر روی اسایش حرارتی کار میکنید تا حدی میتونه نتایج رو تغییر بده ولی باز هم نه زیاد
ممنون مرسی، فقط من چطور میتونم این ارور رو کلا حل کنم؟ راه دیگه ای نداره؟
خیر .. باید زون ها رو به کانوکس تبدیل کنید
