خطای fatal error در energy plus simulation
parniyan goli parniyan goli
2,374 بازدید 1 پاسخ
  1. سلام. به نظر می رسه خطا در نوع مصالح دیوار هست. ولی متوجه نمی شم با چه تغییری درست می‌شه. ممنون میشم اگر راهنماییم کنید.
  2. The simulation has failed because of this fatal error:
    ** Fatal ** Errors occurred on processing input file. Preceding condition(s) cause termination.
the whole comment in panel is: {0;0;0}
0. Current document units is in Meters
  1. Conversion to Meters will be applied = 1.000
  2. Current document units is in Meters
  3. Conversion to Meters will be applied = 1.000
  4. Duplicate surface name! Name is changed to: "srfwall_Dup
  5. Duplicate surface name! Name is changed to: "srfwall_Dup_Dup
  6. Duplicate surface name! Name is changed to: "srfwall_Dup_Dup_Dup
  7. Duplicate surface name! Name is changed to: "srfwall_Dup_Dup_Dup_Dup
  8. [1 of 8] Writing simulation parameters…
  9. [2 of 8] Writing context surfaces…
  10. [2 of 8] Writing context surfaces…
  11. [3 of 8] Writing geometry…
  12. [4 of 8] Writing Electric Load Center - Generator specifications …
  13. [5 of 8] Writing materials and constructions…
  14. Failed to find in library.
  15. [6 of 8] Writing schedules…
  16. [7 of 8] Writing loads and ideal air system…
  17. [8 of 8] Writing outputs…
  18. …
    … idf file is successfully written to : c:ladybugunnamedEnergyPlusunnamed.idf
  19. Analysis is running!..
  20. …
Done! Read below for errors and warnings:
  1. Program Version,EnergyPlus, Version 8.9.0-eba93e8e1b, YMD=2019.12.30 23:25,
  2. ** Severe ** Line: 2664 Index: 0 - Error parsing “Material”. Error in following line.
  3. ** Severe ** ~~~
  4. ** Severe ** Line: 2664 Index: 5 - “0.7” is not a valid Object Type.
  5. ** Severe ** [Construction][EXTWALL0] - Missing required property ‘outside_layer’.
  6. ** Fatal ** Errors occurred on processing input file. Preceding condition(s) cause termination.
  7. …Summary of Errors that led to program termination:
  8. … Reference severe error count=4
  9. … Last severe error=[Construction][EXTWALL0] - Missing required property ‘outside_layer’.
  10. ************* Warning: Node connection errors not checked - most system input has not been read (see previous warning).
  11. ************* Fatal error – final processing. Program exited before simulations began. See previous error messages.
  12. ************* EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors.
  13. ************* EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors.
  14. ************* EnergyPlus Terminated–Fatal Error Detected. 0 Warning; 4 Severe Errors; Elapsed Time=00hr 00min 0.19sec
first.zip
از حروف یا اعداد فارسی به هیچ عنوان به عنوان ورودی استفاده نکنید
این ارور اصلی شماست که داره میگه زمانی که متریال درست کردید یک لایه رو ندادید به ورودی ها
انیس فتح اله گندمی
شیما احمدیان
الهام دانش پور
الهام دانش پور
محاسبه ASE
