ارور ران انرژی در هانی بی
Mandana Mandana
397 بازدید 1 پاسخ
سلام وقت بخیر، من از لیدی باگ 0.0.66 و هانی بی 0.0.63 و اپن استودیو 3.2.0 استفاده می کنم و موقع ران این ارور رو میده. لطفا راهنمایی کنید علت چیه
1. The simulation has not run correctly because of this severe error:
  ** Severe  ** <root>[RunPeriod][customRun][day_of_week_for_start_day] - "Yes" - Failed to match against any enum values.
2. The simulation has not run correctly because of this severe error:
  ** Severe  ** <root>[RunPeriod][customRun][end_day_of_month] - Value type "string" for input "UseWeatherFile" not permitted by 'type' constraint.
3. The simulation has not run correctly because of this severe error:
  ** Severe  ** <root>[RunPeriod][customRun][end_month] - "31" - Expected number less than or equal to 12.000000
4. The simulation has not run correctly because of this severe error:
  ** Severe  ** <root>[RunPeriod][customRun][end_year] - Value type "string" for input "Yes" not permitted by 'type' constraint.
5. The simulation has not run correctly because of this severe error:
  ** Severe  ** <root>[ShadowCalculation][ShadowCalculation 1][shading_calculation_method] - "AverageOverDaysInFrequency" - Failed to match against any enum values.
6. The simulation has not run correctly because of this severe error:
  ** Severe  ** <root>[ShadowCalculation][ShadowCalculation 1][shading_calculation_update_frequency_method] - "30" - Failed to match against any enum values.
7. The simulation has not run correctly because of this severe error:
  ** Severe  ** [json.exception.type_error.302] type must be string, but is null
اولین کار این هست که اخرین ورژن یعنی ورژن هانی بی 66 و لیدی باگ 69 رو نصب کنید
